DRESP3
Bulk Data Entry The DRESP3 card identifies the external function to be called and defines the parameters to be transferred to that function.
When a desired response is not available from OptiStruct, either directly or via equations, it may be calculated through external user-supplied functions implemented in shared/dynamic libraries or external files (see External Responses and Build External Libraries).
| DRESP3 | ID | LABEL | GROUP | FUNCT | REGION | RESP | |||
| DRESPM | RID1 | MODEL NAME1 |
RID2 | MODEL NAME2 |
etc | etc | |||
| VTYPE1 | RID1 | VOPT1 | RID2 | VOPT2 | etc | etc | |||
| etc | |||||||||
| VTYPE2 | RID1 | VOPT1 | RID2 | VOPT2 | etc | etc | |||
| etc | |||||||||
| VTYPEL1 | RID1 | LID1 | VOPT1 | RID2 | LID2 | VOPT2 | |||
| etc. | |||||||||
| VTYPEL2 | RID1 | LID1 | VOPT1 | RID2 | LID2 | VOPT2 | |||
| etc | |||||||||
| VARTYPE1 | ID1 | ID2 | ID3 | ID4 | ID5 | ID6 | ID7 | ||
| ID8 | etc | etc | |||||||
| VARTYPE2 | ID1 | ID2 | ID3 | ID4 | ID5 | ID6 | ID7 | ||
| etc | |||||||||
| VARTYPEn | ID1 | ID2 | ID3 | ID4 | ID5 | ID6 | ID7 | ||
| ID8 | |||||||||
| CELLIN | CI1 | CI2 | CI3 | etc | CIn | ||||
| CELLOUT | CO | ||||||||
| SENSOPT | METHOD |
Alternate Format for CELLIN (cell input) Specifications
| CELLIN | CI1 | thru | CIn |
Alternate Format when VARTYPE is DEIGV
| DEIGV | EIGV1 | LID1 | G1 | C1 | |||||
| EIGV2 | LID2 | G2 | C2 | ||||||
| etc | etc | etc | etc |
Alternate Format when VARTYPE is USRDATA
| USRDATA | STRNG | ||
| etc |
| ID | Response identification
number. Each DRESP3 must have a unique ID with
respect to all other DRESP# cards. No default (Integer > 0) |
| LABEL | User-defined name for the
response. LABEL must begin with an alphabetical
character. No default (Character) |
| GROUP | Defines the shared/dynamic
library or external Microsoft Excel workbook to be used. 18 It references an existing LOADLIB entry in the input
deck. No default (Character) |
| FUNCT | Defines the external
function to be used. No default (Character) |
| REGION | Region identifier 4 Default = blank (Integer > 0 or blank) |
| RESP | Defines the response to be
returned by the external function. Default = 1 (first response in the library) (Integer > 0) |
| DRESPM | Indicates the beginning of a continuation line, which defines model specific response ID and Model Name pairs to be used in a Multi-Model Optimization run. | |
| RID# | Model-specific responses identification numbers. 20 | |
| MODEL NAME# |
User-defined model names defined on the ASSIGN, MMO entry. 20 | |
| VTYPE# | Variable type to
follow.
| RID# | Identification numbers of
the corresponding response defined on the preceding
VTYPE# fields. No default (Integer ≥ 0) |
| VOPT# | Function type that is
applied to the corresponding vector response specified via the
preceding VTYPE# and RID#
fields.
(Character) |
| VTYPEL# | Variable type to
follow.
| LID# | Subcase identification
number for the corresponding response on the preceding
RID# field. No default (Integer ≥ 0) |
| VARTYPE# | Variable type to follow.
Can be one of: DESVAR, DTABLE,
DGRID, DGRIDL,
DGRIDB, DEIGV,
DFREQ1, DFREQ1L,
DRESP1, DRESP1L,
DRESP2, DRESP2L,
DVPREL1, DVPREL2,
DVCREL1, DVCREL2,
DVMREL1, DVMREL2,
DVMBRL1, DVMBRL2,
USRDATA or SAME. 17
22 No default (Character) |
| ID# | When
VARTYPE is DESVAR,
DTABLE, DRESP1,
DRESP2, , DFREQ1,
DVPREL1, DVPREL2,
DVCREL1, DVCREL2,
DVMREL1, DVMREL2,
DVMBRL1, or DVMBRL2 this list
of IDs reference entities of the defined
VARTYPE. When VARTYPE is DGRID or DGRIDB, the list is a list of GRID/Component pairs, where every second value is a component (1, 2, or 3). For example, DGRID, 11, 2 indicates the Y component of grid 11. 17 When VARTYPE is DGRIDL, this list is a list of GRID, Component ID, and Coordinate system IDs, where every second value is a component (1, 2, or 3) and every third value is the coordinate system identification number. For example, DGRIDL, 11, 2, 1 indicates the Y component of grid 11 in a coordinate system of ID = 1. 17 When VARTYPE is DEIGV, the ID# list is replaced by a list of eigenvectors, with each line defining an eigenvector ID, a subcase ID, and a grid/component pair (where the component is one of 1, 2, 3, 4, 5 or 6). When VARTYPE is DRESP1L, DRESP2L, or DFREQ1L the list is a list of response/subcase pairs, where every second value is a subcase ID, for example, DRESP1l, 9, 1, 9, 3 indicates response 9 calculated for subcase 1 and response 9 calculated for subcase 3. When VARTYPE is USRDATA, the list is replaced by a user-defined character string, which is passed to the external function. This character string must be less than 32000 characters. When VARTYPE is SAME, only a single ID should follow. This is the ID of another DRESP3 entry from which data should be copied. No default (Integer ≥ 0, or Character) |
| CELLIN | Indicates that a list of Microsoft Excel worksheet cell references are to follow, that define response input values. 18 19 | |
| CI# | A list of Microsoft Excel
worksheet cell references that define response input values. 18
19 No default (Alphanumeric) |
| CELLOUT | Indicates that a Microsoft Excel Worksheet cell reference is to follow that defines the response output value. 1819 | |
| CO | A Microsoft Excel
worksheet cell reference that defines the response output value.
18
| SENSOPT | Indicates that the sensitivities evaluation method follows. | |
| METHOD | Sensitivities evaluation
method. 16
| EIGVi | Eigenvector numbers. No default (Integer > 0) |
| LIDi | Subcase IDs. No default (Integer > 0) |
| Gi | Grid IDs. No default (Integer > 0) |
| Ci | Component IDs. No default (1, 2, 3, 4, 5, or 6) |
| STRNG | User-defined string to be
passed to the external function. No default (Character string < 32000 characters) |
- DRESP3 entries are referenced from the subcases through one of DESOBJ, DESSUB, or DESGLB.
- DRESP3 entries must have unique identification numbers with respect to DRESP2 and DRESP1 entries.
- DRESP1L, DRESP2L define a response defined with a DRESP1 or DRESP2, respectively, and a SUBCASE. The SUBCASE number 0 should be used for global responses. Similarly, DFREQ1L defines a corresponding DRESP1 response along with the SUBCASE ID to extract the loading frequencies associated with the DRESP1 response being referenced.
- Responses with the same region identifier are grouped together into the same region. If the region identifier is blank, then a separate region is formed for each DRESP3 definition. The RTYPE EXTERNAL on the DSCREEN definition refers to DRESP3 responses. It is important to ensure that responses with the same region identifier reference similar external responses. For further information, refer to Constraint Screening in the User Guide.
- Any number of VARTYPE# continuation lines can be defined. The order in which the VARTYPE# continuation lines are listed on the DRESP2 card is not specified. The same VARTYPE# can be repeated any number of times, in any position, on the card.
- The entries on the DRESP3 card are assigned to the parameters passed to the external function in the order that they occur.
- DRESPi and DRESPiL cards cannot be mixed on one DRESP3 definition.
- If DRESP1L, DRESP2L, DFREQ1L is used for a constrained DRESP3, DESGLB must be used to identify the DRESP3.
- If DRESP1L, DRESP2L, DFREQ1L is used in a DRESP3 objective function, then the DESOBJ that references the DRESP3 must be defined before the first subcase.
- If the DRESP3 data is
referenced by DESOBJ data, the DESOBJ data
must be above the first SUBCASE if:
- DRESP3 contains DRESP1L, DRESP2L, DFREQ1L data
- DRESP3 contains no DRESP1, DRESP2, DRESP1L, DFREQ1L, or DRESP2L data
- DRESP3 contains DRESP1, DRESP2 global responses
The DESOBJ data must be in the correct static or eigenvalue SUBCASE if the DRESP3 contains static or eigenvalue DRESP1 responses.
- DRESP1 of RTYPE = WCOMP, WFREQ, and COMB cannot be referenced by DRESP3 data.
- The RESP field may be
used to request a specific response from the external function. External functions
can be implemented to compute any number of responses and to return any subset of
these responses. This approach has two main benefits:
- There is no need to write a specific external function for each response that you want computed. One general function may be written instead. In many cases, this allows for easier code maintenance and better code reusability.
- OptiStruct will automatically group responses which point to the same external function, and which use the same set of input data. The external function will only be called once for that group of responses, which may save computational time in the library.
- The SAME continuation
line indicates that the input data (DESVAR, and so on) for
the current DRESP3 card is identical to the input data of the
main DRESP3 card. There cannot be any other continuation line
when SAME is used.
This simplifies the DRESP3 definition and reduces potential errors when modifying input decks, either via the HyperMesh interface or manually. Also, as explained above, OptiStruct will group responses that share the same input data.
- The data in the STRNG field is character string based. It provides a convenient way to pass constants to the external response server routines. The maximum number of characters allowed in 32000.
- The eigenvector values provided on the DEIGV continuation are normalized against the mass matrix. No sensitivities are calculated for these values.
- Performance of the sensitivity evaluation
method is problem dependent, and selection of a method depends on the number of
arguments and the cost of each evaluation. The default method works best for most
problems. However, if the approximation module is observed to be very slow with the
default, AUTO or USER can be
tried.
USER: This setup is more complex as it requires user-calculated gradients. However, since finite differences are not used, it can improve the quality of those gradients and may also increase the speed at which those gradients are calculated.
- The DGRID and
DGRIDB
VARTYPE's can be used to select grid point locations as variables
to be passed to the specified equation or function. The grid point locations are
specified as a list of Grid point ID/Component pairs where every second value is a
component. The Grid point ID's are unique grid point identification numbers (ID) and
Components are the grid point locations X1,
X2, and X3 fields on the
GRID Bulk Data Entries.
Figure 1. ExamplesDGRIDB:
The VARTYPE DGRIDB can be used to select grid point locations in the basic coordinate system. The basic coordinate system is the default rectangular coordinate system in OptiStruct.
DGRID:
The VARTYPE DGRID can be used to select the grid point locations in the local coordinate system of each grid point. This local coordinate system may be specified by the CP field of the GRID Bulk Data Entry for a particular grid point of interest. All local (or user-defined) coordinate systems are directly or indirectly based on the default basic coordinate system.
The VARTYPE DGRIDL can be used to select grid point locations as variables to be passed to the specified equation or function with respect to a user-defined coordinate system. The grid point locations are specified as a list of Grid point ID, Components, and Coordinate system IDs, where every second value is a component and ever third value is a user-defined coordinate system ID. The Grid point ID's are unique grid point identification numbers (ID) and Components are the grid point locations X1, X2, and X3 fields on the GRID Bulk Data Entries.
Figure 2. ExampleDGRIDL:
The VARTYPE DGRIDL can be used to select the grid point locations in a user-defined coordinate system for each component. This user-defined coordinate system may be specified as every third value. All local (or user-defined) coordinate systems are directly or indirectly based on the default basic coordinate system.
- An external Microsoft Excel workbook can be referenced on the GROUP field via the LOADLIB I/O Options Entry.
- Multiple CELLIN continuation lines can be specified; each CI# entry on the CELLIN continuation lines corresponds to responses (ID#) defined on the VARTYPE# continuation lines. For further information, refer to External Responses in the User Guide.
- Multiple RID-Model Name pairs can be specified on a single DRESPM continuation line. These responses can be used similar to responses defined via the VARTYPE# -ID# entries. ASSIGN, MMO can be used to identify the filename of the model and the user-defined Model Name that contains the referenced response definition.
- The VTYPE#, RID#, and VOPT# fields can be used to identify the DRESP1 and DRESP2 responses to be passed as vectors to the DRESP3 entry. The VTYPEL#, RID#, LID#, and VOPT# fields can be used to identify the subcase-specific DRESP1 and DRESP2 responses to be passed as vectors to the DRESP3 entry.
- The DFREQ1,
DFREQ1L, DFREQ1V, and
DFREQ1LV options are available to pass loading frequencies
from a corresponding frequency-based DRESP1 response to the
DRESP2/DRESP3. This is supported for
Frequency Response and Random Response Optimization responses.
- DFREQ1
- Loading frequency corresponding to a frequency-based response.
- DFREQ1L
- Loading frequency corresponding to a frequency-based subcase-specific response. Subcase ID should also be provided.
- DFREQ1V
- Vector of loading frequencies for a particular frequency-based response (ATTB field of the corresponding DRESP1 can be blank to pass all loading frequencies of interest corresponding to the referenced DRESP1 response).
- DFREQ1LV
- Vector of loading frequencies for a particular frequency-based subcase-specific response. Subcase ID should also be provided. (ATTB field of the corresponding DRESP1 can be blank to pass all loading frequencies of interest corresponding to the referenced DRESP1 response).
