HOURGLS
Bulk Data Entry Defines hourglass control parameters to reduce spurious zero-energy modes in elements with reduced integration.
| HOURGLS | HGID | HGTYP | HGFAC |
| HOURGLS | 2 | 2 | .05 |
| HGID | Hourglass control card identification
number. No default (Integer > 0) |
| HGTYP | Hourglass control types. 2
| HGFAC | Scale factor for hourglass control
forces Default = 0.1 for HGTYP=1 (0.05 < HGFAC < 0.15) Default = 0.05 for shells with HGTYP=2 (0.0 < HGFAC < 0.1) Default = 1.0 for solids with HGTYP=2 (0.0 < HGFAC ≤ 1.0) Default = 0.01 for HGTYP=4 (0.0 < HGFAC < 0.1) |
- HOURGLS Bulk Data Entries can be selected in element property definition to disable default hourglass control parameters.
- HGTYP=1 and HGTYP=2 are available for MAT1/MATS1. For MATHE, only HGTYP=2 and HGTYP=4 are available. In most situations, HGTYP=4 exhibits good performance for MATHE. HGTYP=4 is only available for MATHE materials.
- HOURGLS entry when referenced on HGID field of the corresponding PSOLID, PLSOLID, or PSHELL entries will overwrite the values defined via PARAM, HOURGLS.
- When HGTYP=2 is defined, the input HGFAC is neglected in the presence of MAT1/MATS1 and a fixed value of HGFAC=1.0 is used.
