RADM
Bulk Data Entry Defines the radiation material properties of a surface element for heat transfer analysis.
RADM RMID ABSORP EMIS1
RADM 24 0.2 1.0
RMID Radiation material property entry identification number.
No default (Integer > 0)
ABSORP Surface absortivity.
No default (0.0 ≤ Real ≤ 1.0)
EMIS1 Surface emissivity.
  1. The RADM entry can be referenced by a CHBDYE Bulk Data Entry.
  2. The Radiation Heat Flux is calculated as follows, between the surface element and the black-body space node.(1)
    q=σ⋅FAMB⋅( ε e ( T e + T abs ) 4 − α e ( T amb + T abs ) 4 ) MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyCaiabg2 da9iabeo8aZjabgwSixlaabAeacaqGbbGaaeytaiaabkeacqGHflY1 daqadaqaaiabew7aLnaaBaaaleaacaWGLbaabeaakmaabmaabaGaam ivamaaBaaaleaacaWGLbaabeaakiabgUcaRiaadsfadaWgaaWcbaGa amyyaiaadkgacaWGZbaabeaaaOGaayjkaiaawMcaamaaCaaaleqaba GaaGinaaaakiabgkHiTiabeg7aHnaaBaaaleaacaWGLbaabeaakmaa bmaabaGaamivamaaBaaaleaacaWGHbGaamyBaiaadkgaaeqaaOGaey 4kaSIaamivamaaBaaaleaacaWGHbGaamOyaiaadohaaeqaaaGccaGL OaGaayzkaaWaaWbaaSqabeaacaaI0aaaaaGccaGLOaGaayzkaaaaaa@5D96@
    Where,
    q MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyCaaaa@36EC@
    Radiation heat flux.
    σ
    Stefan-Boltzmann constant defined via PARAM, SIGMA.
    FAMB MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaaeOraiaabg eacaqGnbGaaeOqaaaa@3918@
    Radiation view factor between the element face and the ambient space node.
    ε e MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqyTdu2aaS baaSqaaiaadwgaaeqaaaaa@38B3@
    Surface emissivity of the surface element, defined by EMIS1 on the RADM entry.
    α e MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqySde2aaS baaSqaaiaadwgaaeqaaaaa@38AB@
    Surface absorptivity of the surface element, defined by ABSORP field on the RADM entry.
    T e MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamivamaaBa aaleaacaWGLbaabeaaaaa@37E5@
    Surface temperature.
    T abs MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamivamaaBa aaleaacaWGHbGaamOyaiaadohaaeqaaaaa@39C0@
    Absolute temperature scale defined via PARAM, TABS.
    T amb MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamivamaaBa aaleaacaWGHbGaamyBaiaadkgaaeqaaaaa@39BA@
    Ambient temperature.
  3. For a Heat Transfer Analysis via Radiation, PARAM,TABS can be used to define the absolute temperature scale, and PARAM,SIGMA is used to specify the Stefan-Boltzmann constant. Additionally, a RADBC entry can be used to define radiation boundary conditions.
