DMGEVO
Bulk Data Entry Defines the damage evolution.
DMGEVO | DMGEVOID | TYPE | SHAPE | ||||||
MMXFM | ALPHA | W1 | W2 | W3 |
Example (Damage based on energy with power law mixing)
DMGEVO | 24 | COHENRG | EXP | ||||||
1 | 1.2 | 2.0 | 5.0 | 5.0 |
Example (Damage based on energy with B-K form mixing)
DMGEVO | 57 | COHENRG | LIN | ||||||
2 | 1.5 | 24.0 | 50.0 |
Example (Damage based on energy no mode mixing)
20.0 |
Example (Damage based on opening)
DMGEVO | 1 | COHDISP | EXP | ||||||
2.0 | 20.0 |
DMGEVOID | Damage evolution
TYPE | Damage evolution type.
No default |
SHAPE | Profile shape of the
traction-opening curve in the descending part.
MMXFM | Mode mixed form (only
for TYPE = COHENRG).
ALPHA | When
TYPE = COHDISP with
SHAPE = EXP, it is the
exponent for the traction-separation curve. When TYPE = COHENRG with MMXFM = 1, it is the exponent for the mixing formula. When TYPE = COHENRG with MMXFM = 2, it is the mixing coefficient. No default (Real > 0) |
W1. W2, W3 | Material curve
parameters. When
TYPE=COHDISP, only
W1 is required.
When
TYPE=COHENRG, the
parameters are the energies that can be dissipated in pure
normal and pure shear separation.
When
TYPE=COHENRG with
MMXFM= Blank.
for
TYPE=COHDISP or for TYPE=COHENRG |
- The material identification number should be unique for all MAT1, MAT2, MAT3, MAT8, MAT9, MGASK, MCOHE, MCOHED, DMGINI, and DMGEVO entries.
- For additional information, refer to Cohesive Zone Modeling in the User Guide.
