Description of various Combined Loadings options.
See
Combined
Loadings for more information.
- Loading Type
- List 1 allows selection of Dynamic or Static loading.
- List 2 allows selection of Static loading only.
- Affects Gap
- Defines if the loading selected does or does not affect the gap.
- OFF
- Both the selected loadcases do not affect the original
gap.
- Plotting is performed by combining the relative
displacements.
- Gap +/- tolerance remains same.
- ON
- Corresponding loadcase affects the nominal gap and are
updated as follows:
New Gap = Nominal Gap - Relative Displacement of
Loadcase (with Affects Gap On) in Z
direction.
Min Gap = New Gap - Tolerance
Max Gap = New Gap + Tolerance
- Session Type
- Summary Analysis: Perform only a summary analysis and to view basic
results.
- Full Analysis: Perform full analysis and to check the effects.
