Optimization
Setup an optimization solver deck to get solution proposals.
Solving any engineering problem using simulation can be done in two ways; iterative changes until reaching a solution, or using Optimization. The objective of the Optimization feature in SnRD enables the CAE analyst to seamlessly setup an optimization run based on analysis performed in the Post Processing and Sensitivity Analysis steps.
- Topology Optimization: Systematic problems
- Free Size Optimization: Non Systematic problems
Figure 1. Optimization Deck Setup- Loadcase setup: Modal Transient (MTRAN) analysis is changed to Modal Frequency Response (MFREQ)
- Optimization parameters set-up: Responses and Constraints
