Use DoE/Stochastics to understand the parameter variation study.
DoE and Stochastics module allows you to investigate hundreds of simulation
results in a powerful way. When multiple variational studies have been setup, and
results imported, SnRD will automatically post process all the
Rattle and Squeak results for high level and deep dive investigation. You can refer to
Variabilities Analysis for more
information.Use the exported TPL file in
Altair
HyperStudy to generate DoE/Stochastics results database
and reports required for DoE/Stochastics study.
