Evaluate DoE/Stochastics
Steps to evaluate DoE/Stochastics runs.
Browse and select the OptiStruct
.FEM) solver file, pre output CSV and the results file using the Post Processing tab. - Click DoE/Stochastics tab.
- Click HyperStudy Results Database.
Click
to browse and select XML file
exported for Variability Study.
Click Calculate.
Once complete, a user message will appear.
- Click OK
Click Apply Filters.
This lists the runs for the selected filters.
Click Display Results.
This lists and displays the results for selected filters.
- Optional: Click SnR Results Database.
- Select the required options under Data Filtering panel.
- Select the required runs from the Run Selection list.
Click Display Selection.
The results for the selected runs are plotted.
