Manage E-Points
Use the Manage E-Points tool to modify local system collectors and evaluation points.
For some of the quick risk analysis in order to obtain quick analysis of an E-Line, you may require to modify or reduce the number of evaluation points on E-Lines. Also, there may be cases where you might have to modify the local system collector orientation. Use the Manage E-Points tool to delete connections and rotate Local Coordinate Systems (LCS).
- Delete connections in places where they are not needed to speed up
simulation and post processing.Restriction: This workflow is not supported from 2022.1 onward.
- Rotate LCS to ensure it is properly aligned with the actual Gap direction.
- Relocate the RBE3 elements of the Realized E-line to a nearby element to ensure a proper definition of the E-point elements.
