Setup Variability Study
From the Setup group, select Variability
Study.
- Select the type of model parameter to include in the variation study.
- Select properties/curves/material in the graphics area or by using the advanced selection dialog.
In the microdialog specify the lower and upper bounds
for the variation.
Optional: Click on
to update the name.
Click
Variation studies with design variables created for all selected study parameters.Restriction: Variability Study is only supported for Dynamic Event and only one loadcase at a time. You can select which load case to include in the study at export. - Optional:
Review and edit the created Variation Studies and Variables in Review Variation
Study Table:
Figure 3.
