Optimization Deck Setup
![](../../resources/user-manual/post/systematic_optimization.png)
![](../../resources/user-manual/post/snrdx_optimization_sys.png)
View new features for HyperWorks 2022.2.
Explore the SnRD Pre-Processing user interface.
Explore SnRD Post Processing User Interface.
Use SnRD Post Processing tab to load and process the results.
Use Sensitivity Analysis to study modal contribution.
Study the squeak and rattle issues under combined loading conditions.
Setup an optimization solver deck to get solution proposals.
Setup Systematic Optimization.
Setup Non Systematic Optimization.
Export of optimization solver deck.
Use DoE/Stochastics to understand the parameter variation study.
Use of Altair Ziegler SnR Material Database.
