Elements
| LS-DYNA |
OptiStruct |
| *ELEMENT_MASS |
CONM2 |
| *ELEMENT_BEAM |
CBAR |
| *ELEMENT_SHELL |
CTRIA3,CQUAD4, CQUAD8, CTRIA6 |
| *ELEMENT_SOLID |
CTETRA4/CHEXA8/CPENTA6 |
| *CONSTRAINED_SPOTWELD |
RBAR |
| *ELEMENT_PLOTEL |
PLOTEL |
| *CONSTRAINED_INTERPOLATION |
RBE3 |
| *CONSTRAINED_NODE_SET |
RBE2 |
| *ELEMENT_DISCRETE |
CELAS1 |
Properties
| LS-DYNA |
OptiStruct |
| *SECTION_SOLID |
PSOLID |
| *SECTION_SHELL |
PSHELL |
Materials
| LS-DYNA |
OptiStruct |
| *MAT_MODIFIED_PIECEWISE_LINEAR_ELASTICITY |
MATS1 |
| *MAT_TABULATED_JOHNSONCOOK |
MATS1 |
| *MAT_PLASTICITY_COMPRESSION_TENSION |
MATS1 |
All the LS-DYNA materials are mapped MAT1 in OptiStruct.
Boundary Conditions
| LS-DYNA |
OptiStruct |
| *BOUNDARY_SPC |
SPC |
| *LOAD_NODE_POINT |
FORCE, MOMENT |
| *LOAD_SEGMENT |
PLOAD4 |
| *INITIAL_TEMP |
TEMP |
Coordinate Systems
| LS-DYNA |
OptiStruct |
| *DEFINE_COORDINATE_NODE |
CORD1R |
| *DEFINE_COORDINATE_ SYSTEM
CORD2R |
