LS-DYNA to Radioss Conversion Mapping
Airbag
| LS-DYNA | Radioss |
| *AIRBAG_SIMPLE_AIRBAG_MODEL | /MONVOL/AIRBAG1 |
| *AIRBAG_SIMPLE_PRESSURE_VOLUME | /MONVOL/PRES |
| *AIRBAG_SIMPLE_AIRBAG_MODEL_{ID | /MONVOL/AIRBAG1, /MAT/GAS, /PROP/INJ1 |
| *ELEMENT_SEATBELT_ACCELEROMETER | /ACCEL,/SKEW/MOV,/ADMAS |
Boundary
| LS-DYNA | Radioss |
| *BOUNDARY_PRESCRIBED_MOTION | IMPASS, IMPVEL or IMPDISP |
Constrained Definitions
| LS-DYNA | Radioss |
| *CONSTRAINED_Extra_NODES_SET | /RBODY,/GRNOD/GRNOD,/GRNOD/PART |
| *CONSTRAINED_JOINT_REVOLUTE | /SPRING,/PROP/KJOINT2/ property type 2 |
| *CONSTRAINED_JOINT_SPHERICAL | /SPRING,/PROP/KJOINT2/ property type 1 |
| *CONSTRAINED_JOINT_CYLINDRICAL | /SPRING,/PROP/KJOINT2/ property type 3 |
| *CONSTRAINED_JOINT_LOCKING | /PROP/KJOINT2/property type 8 |
| *CONSTRAINED_JOINT_TRANSLATIONAL | SPRING elements, /PROP/KJOINT2/ property type6 |
| *CONSTRAINED_JOINT_STIFFNESS_GENERALIZED | /SPRING |
| *CONSTRAINED_RIGID_BODY | /RBODY |
Control Cards
| LS-DYNA | Radioss |
| *CONTROL_ADAPTIVE | ADMESH_GLOBAL, ADMESH_SET |
Contact
| LS-DYNA | Radioss |
| *SECTION_BEAM ELFORM=1 | /PROP/TYPE18 |
| *CONTACT_TIED_SHELL_EDGE_TO_SURFACE_ID | /INTER/TYPE2,/INTER/TYPE10 |
| *CONTACT_TIED_NODES_TO_SURFACE | /INTER/TYPE2,/INTER/TYPE10 |
| *CONTACT_AUTOMATIC_GENERAL | /INTER/TYPE7,/INTER/TYPE10 |
Contact Interfaces
| LS-DYNA | Radioss |
| *CONTACT_AUTOMATIC_GENERAL | INTER/TYPE7 |
| *CONTACT_AUTOMATIC_GENERAL_INTERIOR | INTER/TYPE7 |
| *CONTACT_AUTOMATIC_NODES_TO_SURFACE | INTER/TYPE7 |
| *CONTACT_AUTOMATIC_ONE_WAY_SURFACE_TO_SURFACE | INTER/TYPE7 |
| *CONTACT_AUTOMATIC_SINGLE_SURFACE | INTER/TYPE7 |
| *CONTACT_AUTOMATIC_SURFACE_TO_SURFACE | INTER/TYPE7 |
| *CONTACT_INTERIOR | INTER/TYPE7 |
| *CONTACT_SPOTWELD | /TYPE2 |
Components
| LS-DYNA | Radioss |
| *DAMPING_PARTS_OPTIONS | PART |
| *PART_OPTIONS | PART |
| *INCLUDE_STAMPED_PART | PART |
Curves
| LS-DYNA | Radioss |
| *DEFINE_CURVE | FUNCT |
Database
| LS-DYNA | Radioss |
| *DATABASE_EXTENT_BINARY | ANIM/SHELL/TENS/STRESS/UPPER ANIM/SHELL/TENS/STRESS/MEMB ANIM/BRICK/TENS/STRESS ANIM/ELEM/EPSP ANIM/SHELL/EPSP/UPPER ANIM/SHELL/SPEP/LOWER |
| *DATABASE_HISTORY | /TH/SHEL,/TH/SH3N,/TH/BRIC cards |
| *DATABASE_HISTORY_NODE | /TH/NODE |
| *DATABASE_BINARY_D3PLOT | /TFILE/1 |
| *DATABASE_OPTION | /TFILE/1 |
| *DATABASE_HISTORY_NODE_SET_LOCAL | /TH/NODE |
| *DATABASE_CROSS_SECTION_PLANE | /SECT |
| *DATABASE_CROSS_SECTION_PLANE_OPTION (CIRCLE) | /SECT/PLANE |
Define
| LS-DYNA | Radioss |
| *DEFINE_TABLE | /TABLE |
| *DEFINE_CURVE | /FUNCT |
Elements
| LS-DYNA | Radioss |
| *ELEMENT_SHELL | SHELL, SH3N |
| *ELEMENT_SOLID | BRICK, TETRA44 |
| *ELEMENT_MASS | ADMAS/TYPE5 |
| *ELEMENT MASS PART | /ADMAS/TYPE5 |
| *ELEMENT MASS SET | /ADMAS/TYPE6 |
| *ELEMENT_BEAM | BEAM |
| *ELEMENT_BEAM_ORIENTATION | /BEAM,/SPRING |
| *ELEMENT_DISCRETE | SPRING2N |
| *ELEMENT_SEATBELT_ACCELEROMETER | ACCEL,/SKEW/MOV,/ADMAS |
Loads
| LS-DYNA | Radioss |
| *BOUNDARYSPC_NODE | /BCS |
| *BOUNDARY_SPC_NODE/SET | BCS |
| *LOAD_BODY | /GRAV |
| *LOAD_NODE_POINT/SET | CLOAD |
| *INITIAL VELOCITY_BODY | /INVEL/TRA, /INVEL/ROT |
| *INITIAL_VELOCITY_NODE/GENERATION/ RIGID BODY | INIVEL |
Materials
| LS-DYNA | Radioss |
| *MAT_ADD_EROSION | /FAIL/TAB1 and /FAIL/TENSSTRAIN |
| *MAT_ARUP_ADHESIVE/MAT_169 | /FAIL/CONNECT, /PROP/CONNECT |
| *MAT_CABLE_DISCRETE_BEAM/LAW_071 | /SPRING, property /PROP/SPRING |
| *MAT_COHESIVE_MIXED_MODE_ELASTOPLASTIC_RATE/MAT_240 | /MAT/LAW59, /FAIL/CONNECT and /PROP/CONNECT, /MAT/LAW83 |
| *MAT_COMPOSITE_DAMAGE/MAT_022 | /MAT/LAW25 |
| *MAT_COMPOSITE_FAILURE_SHELL_MODEL / MAT_059 | MAT/LAW25 (CRASURV) |
| *MAT_ELASTIC | M1_ELASTIC |
| *MAT_ELASTIC/MAT_001 | /MAT/LAW01,/MAT/LAW02 |
| *MAT_GENERAL_VISCOELASTIC | /MAT/LAW42 |
| *MAT_LINEAR_ELASTIC_DISCRETE_BEAM/LAW_066 | /SPRING,/PROP/SPR_BEAM |
| *MAT_PLASTIC_KINEMATIC | M36_PLASTIC_TAB |
| *MAT_PLASTIC_KINEMATIC | /MAT/LAW44 |
| *MAT_NULL | M0_VOID |
| *MAT_ORTHOTROPIC_ELASTIC/MAT_002 | /MAT/FABRI |
| *MAT_OGDEN_RUBBER / LAW_077_O | /MAT/LAW42 (Ogden) |
| *MAT_PLASTICITY_WITH_DAMAGE | LAW88 for rubber and LAW70 for foam |
| *MAT_PLASTIC_KINEMATIC_OPTION/MAT_003 | /MAT/LAW44 and /MAT/LAW2 |
| *MAT_RIGID | M1_ELASTIC (nodes of material defined as /RBODY) |
| *MAT_PIECEWISE_LINEAR_PLASTICITY | M36_PLAS_TAB |
| *MAT_POWER_LAW_PLASTICITY_OPTION / MAT_018 | /MAT/PLAS_TAB(LAW36) |
| *MAT_SIMPLIFIED_JOHNSON_COOK | M2_PLAS_JOHNS_ZERIL |
| *MAT_BLATZ_-KO_RUBBER | M42_OGDEN |
| *MAT_SPRING_NONLINEAR_ELASTIC | P13_SPR_BEAM |
| *MAT_SPOTWELD_TITLE | P13_SPR_BEAM |
| *MAT_SPRING_ELASTIC | /PROP/TYPE13 |
| *MAT_SEATBELT | /PROP/SPRING |
| *MAT_SEATBELT/MAT_B01 | /PROP/SPRING(TYPE4),/PROP/SPR_PUL(TYPE12) |
| *MAT_MOONEY_RIVLIN_RUBBER | /M42_OGDEN /M69 |
| *MAT_LOW_DENSITY_FOAM | /MAT/LAW38 |
| *MAT_SOLID/TYPE45 | /MAT/LAW70 |
| *MAT_FABRIC/MAT_034 | /MAT/FABRI |
| MAT_NONLINEAR_ELASTIC_DISCRETE_BEAM_TITLE | /SPRING,/PROP/SPR_BEAM |
| MAT_VISCOELASTIC_OPTION/MAT_006 | MAT/LAW42 |
| MAT_SPRING_GENERAL_NONLINEAR/MAT_S06 | /PROP/SPR_BEAM |
| *MAT_DAMPER_VISCOUS | /SPRING,/PROP/SPR_BEAM |
| *MAT_SOIL_AND_FOAM_FAILURE/MAT_014 | /MAT/LAW21 |
| *MAT100(spotweld) | /PROP/TYPE13 |
| *MAT119 MAT_GENERAL_NONLINEAR_6DOF_DISCRETE_BEAM_TITLE | /PROP/TYPE13 |
| *MAT_JOHNSON_COOK/MAT_015 | /MAT/LAW02 (with failure model) |
| *MAT_SHAPE_MEMORY | //MAT/LAW71 |
| MAT_ISOTROPIC_ELASTIC_PLASTIC_OPTION / MAT_012 | /MAT/LAW02 |
| *MAT_GENERAL_NONLINEAR_6DOF_DISCRETE_BEAM_TITLE | /PROP/TYPE13 |
Properties
| LS-DYNA | Radioss |
| *SECTION_BEAM | P3_BEAM |
| *SECTION_DISCRETE | P4_SPRING |
| *SECTION_SHELL | P1_SHELL |
| *SECTION_SOLID | P14_SOLID |
Rigid Walls
| LS-DYNA | Radioss |
| *RIGIDWALL_GEOMETRIC_FLAT_OPTIONS | RWALL |
| *RIGIDWAL GEOMETRIC,FLAT | /RWALL/PARAL |
| *RIGIDWAL GEOMETRIC,CYLINDER | /RWALL/CYL |
| *RIGIDWAL GEOMETRIC,PRISM | /RWALL/PARAL |
| *RIGIDWAL GEOMETRIC,SPHERE | /RWALL/SPHER |
| *RIGIDWALL_PLANAR_OPTIONS | RWALL |
Section
| LS-DYNA | Radioss |
Sets
| LS-DYNA | Radioss |
| *SET_NODE_ADD | /GRNOD/NODE |
| *SET_NODE_ADD_ADVANCED | /GRNOD/GRNOD |
| *SET_NODE_LIST | /GRNOD/GRNOD |
| *SET_NODE_GENERAL | /GRNOD/GRNOD |
| *SET_NODE_LIST_GENERATE | /GRNOD/GRNOD |
Systems
| LS-DYNA | Radioss |
| *DEFINE_COORDINATE_NODES | SKEW/MOVE/ |
| *DEFINE_COORDINATE_SYSTEM | SKEW/FIXED |
Time History Definitions
| LS-DYNA | Radioss |
| *DATABASE_HISTORY_BEAM | TH/BEAM |
| *DATABASE_HISTORY_NODE | TH/NODE |
| *DATABASE_HISTORY_SHELL | TH/SHEL |
| *DATABASE_HISTORY_SOLID | TH/BRIC |
| *DATABASE_HISTORY_TSHELL | TH/THSH |
| *DATABASE_EXTENT_BINARY | /ANIM/SHELL/TENS/STRESS/UPPER |
| *DATABASE OPTION | /TFILE/1 |
