LS-DYNA to PAM-CRASH Mapping
Elements
| LS-DYNA | PAM-CRASH |
| *ELEMENT_SHELL | SHELL |
| *CONSTRAINED NODAL RIGID BODY | RBODY/MTOCO |
| *ELEMENT BEAM | SPRGBM |
| *BOUNDARY SPC NODE | BOUNC |
| *CONSTRAINED NODE SET | MTOCO/NODCO |
Sets
| *SET_SHELL_LIST | Element set |
| *SET_NODE_LIST | Nodes set |
| *SET_PART_LIST | Component sets |
Contacts
| *CONTACT_AUTOMATIC_GENERAL_ID | CNTAC46 |
| *CONTACT_AUTOMATIC_SINGLE_SURFACE_ID | CNTAC36 |
| *CONTACT_AUTOMATIC_Sinlge_surface(with mortor) | CNTAC36 |
| *CONTACT_AUTOMATIC_SURFACE_TO_SURFACE_ID | CNTAC33 |
| *CONTACT_AUTOMATIC_SURFACE_TO_SURFACE_ID(with mortor) | CNTAC33 |
| *CONTACT_TIED_SHELL_EDGE_TO_SURFACE_BEAM_OFSET_ID | TIED |
| CONTACT TIED EDGE SHELL TO SURFACE | TIED |
Property
| *SECTION_BEAM | PART_1D (BEAM) |
| *SECTION_BEAM(SpringBeam) | PART_1D (SPRINGBM) |
| *SECTION_SHELL | PART_2D |
| *SECTION_SOLID | PART_3D |
