Activate or Deactivate a Datum Plane
                From the HyperGraph 3D toolbar, click the Datum
                    Planes icon,  . .
- Select a datum plane from the Datum list or from the screen.
- To activate a datum plane, select the Datum check box so that a check mark is displayed.
- To deactivate a datum plane, select the Datum check box again to remove the check mark.
