View new features for HyperWorks 2022.2.
Learn how to manipulate plot data using the Plot Browser and other user interface tools and options.
Loads Flux motor efficiency files in text format.
Edit existing curves or add new curves to the current plot.
Create waterfall plots from XY force response data and input pulses.
Define curve attributes.
Axes can be added to plots using the Axes panel.
Retrieve individual point data on any curve in the active window.
The Data Query panel uses vertical cutting surfaces for viewing and plotting non-planer cross sections.
Provides quick access to the Datums and Notes tools.
The Datum Planes panel allows you to insert reference datum planes to plots.
Notes are text boxes placed in the 3D Chart window for labeling points,         describing trends, and relating additional curve information in a plot. Click the Notes
                                    tool,  , to display the Notes panel.
From the HyperGraph 3D3D Chart modeling window, right-click to display the context menu.
