View a Cross Section of a Curve
                From the HyperGraph 3D toolbar, click the Datum
                    Planes icon,  . .
- Click Add under the Datum list.
- Set the plane type to Clipping plane.
- Click Reverse under the list of plane types to view the opposing side of the curve, if desired.
- Select the Position tab.
                Under Method:, set the orientation method:
                - Vertical along the Z axis
- Horizontal along the X axis
- Horizontal along the Y axis
- Three points
- Click two points on the curve to define the Orientation points.
Or
                If you selected Three points, click three points on the
                The plane passes between these points along the Method axis.
- Set the Plane type to Cross section to display the cross section only.
