Generate an XY Plot from the Datum Plane's Intersection
                From the HyperGraph 3D toolbar, click the Datum
                    Planes icon,  . .
- Select a datum plane from the Datum list.
- Select Cross section or Clipping plane.
- Select the Create XY Plot tab.
                Under Place curve on:, select Preview plot,
                        New plot, or Existing
                    plot.
                - Preview plot
- Creates the curve in a pop-up window.
- New plot
- Creates the curve in a new plot window.
- Existing plot
- Creates the curve in an existing plot window.
- If you select Existing plot, select an existing plot window from the tree selection.
- Click Apply to create the plot.
