Position a Datum Plane
                From the HyperGraph 3D toolbar, click the Datum
                    Planes icon,  . .
- From the Datum Planes panel, select a datum plane from the Datum list or from the screen.
- Select the Position tab.
                Under Method:, set the orientation method:
                - Vertical along the Z axis
- Horizontal along the X axis
- Horizontal along the Y axis
- Three points
- Under Orientation:, select points on the curve to define the orientation.
- Select a base point or enter XYZ values to define the location.
- Click Apply.
