Remap Nodes
Use the Edit Elements: Remap tool to remap a series of nodes to a selected line list
                From the Elements ribbon, click the Edit Elements > Remap tool.
Figure 1.Elements are colored according to how well they adhere to the pre-set quality requirements defined in the criteria file. - Select a list of nodes in a specific direction or by path.
 - Click the Lines selector on the guide bar.
 - Select a line or a list of lines by path following the same sequence used for nodes.
                Click Remap.
Figure 2. Before Remap
Figure 3. After RemapThe figures above show selected nodes on a shared feature line and those nodes becoming evenly distributed across the surface edge after remapping.
Note: To get proper mapping, you must select nodes and lines in the same sequence or path.
