Relocate Nodes/Elements to their Initial Locations
Use the Edit Elements: Origin tool to relocate moved nodes and elements to associated geometry.
                From the Elements ribbon, click the Edit Elements > Origin tool.
Figure 1. - Select nodes or elements.
                Click
 on the guide bar.
Figure 2.Note:- If nodes are moved within the surface/edge, the current position of the node is updated as the origin. Therefore, nodes are not moved back to their initial locations upon using the Origin tool.
 - If nodes are moved away from the surface/edge, nodes are always
                                    brought back to the initial locations upon using the Origin
                                    tool, even after multiple node movements.
Figure 3.
