*LOAD_BODY
LS-DYNA Input Interface KeywordDefines an acceleration load.
| (1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
| *LOAD_BODY_{OPTION} | |||||||
| LCID | SF | CID | |||||
Definition
| OPTION | Direction of the acceleration load. The force from the
acceleration is applied in the opposite direction. X, Y, Z |
| LCID | Curve identifier for gravity acceleration load as function of
time. (Integer) |
| SF | Scaling coefficient applied to the ordinate of the gravity
curve. Default = 1.0 (Real) |
| CID | Coordinate system identifier. (Integer) |
- This keyword maps to /GRAV.
