*MAT_081 (PLASTICITY_WITH_DAMAGE)
LS-DYNA Input Interface KeywordDefines an isotropic elasto-plastic material using tabulated stress versus plastic strain input for different strain rates and simple damage model.
| (1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
| *MAT_081 or *MAT_PLASTICITY_WITH_DAMAGE | |||||||
| mat_ID | E | ν | SIGY | ETAN | FAIL | ||
| C | P | LCSS | LCSR | EPS_max | VP | Numint | |
| EPS1 | EPS2 | EPS3 | EPS4 | EPS5 | EPS6 | EPS7 | EPS8 |
| ES1 | ES2 | ES3 | ES4 | ES5 | ES6 | ES7 | ES8 |
Definition
| mat_ID | Material identifier. (Integer) |
| Initial density. (Real) |
| E | Young’s modulus. (Real) |
| v | Poisson’s ratio. Default = 0 (Real) |
| SIGY | Yield stress, ignored if LCSS >
0 or stress-strain values
EPS1-EPS8,
ES1-ES8
specified. (Real) |
| ETAN | Plastic hardening modulus, not used if
LCSS >
0. (Real) |
| FAIL | Plastic strain for material softening. (Real) |
| C | Strain rate coefficient. (Real) |
| P | Strain rate exponent. (Real) |
| LCSS | Stress versus plastic strain curve or table
| LCSR | Curve identifier defining the scaling coefficient for the
stress-strain curve for a corresponding strain
rate. (Integer) |
| EPS_max | Plastic strain for element deletion. (Real) |
| VP | Strain rate type flag:
(Integer) |
| EPS1-EPS8 | Plastic strain data points. (Real) |
| ES1-ES8 | Yield stress data points. (Real) |
- This keyword maps to /MAT/LAW36 (PLAS_TAB) or /MAT/LAW44 (COWPER) according to the input.
- The option “_TITLE” can be added to the end of this keyword. When “_TITLE” is included, an extra 80 characters long line is added after the keyword input line which allows an entity title to be defined.
