::GetCurrentSelectionVarname
This command gets the full varname of the currently selected entry in a mdlCollector widget.
::model::mdlCollector::GetCurrentSelectionVarname path
MotionView Tcl GUI
path
The full path to the mdlCollector widget of interest. This argument is the return value of the ::model::mdlCollector procedure used to create an mdlCollector.
To get the varname of the current selection of the value of an mdlCollector widget:
::model::GetClientHandle clnt
clnt GetModelHandle mdl
clnt ReleaseHandle
mdl InterpretEntity mrk Marker m_0 "\"Marker 0\"" "" ""
mdl ReleaseHandle
set dlg [toplevel .dlg]
set frm [frame $dlg.frm -padx 10 -pady 10]
grid $frm -row 0 -column 0 -sticky nesw
set coll [::model::mdlCollector .dlg.frm.coll mrk "origin" "Point" -reference ]
grid $coll -row 0 -column 0
set value  [ ::model::mdlCollector::GetCurrentSelectionVarname $coll ]
mrk ReleaseHandle
None.
