::SetLabelText
This command sets the label text for an mdlCollector widget.
::model::mdlCollector::SetLabelText path label_text
MotionView Tcl GUI
path
The full path to the mdlCollector widget of interest. This argument is the return value of the ::model::mdlCollector procedure used to create an mdlCollector.
label_text
New text for the label.
To set the label text of an mdlCollector widget:
::model::GetClientHandle clnt
clnt GetModelHandle mdl
clnt ReleaseHandle
mdl InterpretEntity mrk Marker m_0 "\"Marker 0\"" "" ""
mdl ReleaseHandle
set dlg [toplevel .dlg]
set frm [frame $dlg.frm -padx 10 -pady 10]
grid $frm -row 0 -column 0 -sticky nesw
set coll [::model::mdlCollector .dlg.frm.coll mrk "origin" "Point" -reference \
          -label "Label:" ]
grid $coll -row 0 -column 0
::model::mdlCollector::SetLabelText $coll "New Label:"
mrk ReleaseHandle
None.
