::GetFirstCollector
This command will be used to get the address of the first collector within the mdlOrientation widget.
::model::mdlOrientation::GetFirstCollector argFrm
MotionView Tcl
argFrm
We need to pass the path of the mdlOrientation widget as the above argument, from which we need to get the address of the first collector.
::model::GetClientHandle client
client GetModelHandle mod
mod InterpretEntity mrk Marker mrk_0 "\"Marker 0\"" "" ""
set top [toplevel .test]
set colFrm [frame $top.tmpFrm1 ]
pack $colFrm
set ornt [::model::mdlOrientation $colFrm.ornt mrk]
pack $ornt
client ReleaseHandle
mod ReleaseHandle
mrk ReleaseHandle
tk_messageBox -message "First collector path: [::model::mdlOrientation::GetFirstCollector .test.tmpFrm1.ornt]"
On successful execution of the command, it will return the address of the first collector widget.
