::GetLastCollectorType
This command will be used to get the type of the last collector within the orientation widget “mdlCollector/mdlListCollector”.
::model::mdlOrientation::GetLastCollectorType argFrm
MotionView Tcl
argFrm
We need to pass the path of the mdlOrientation widget as the above argument, from which we need to get the type of the last collector.
::model::GetClientHandle client
client GetModelHandle mod
mod InterpretEntity mrk Marker mrk_0 "\"Marker 0\"" "" ""
set top [toplevel .test]
set colFrm [frame $top.tmpFrm1 ]
pack $colFrm
set ornt [::model::mdlOrientation $colFrm.ornt mrk]
pack $ornt
client ReleaseHandle
mod ReleaseHandle
mrk ReleaseHandle
set colType [::model::_private::mdlOrientation::GetLastCollectorType  .test.tmpFrm1.ornt]
tk_messageBox -message "Last collector type: $colType"
On successful execution of the command, it will return the type of the last collector widget.
