poIGraphicMaterial SetMetallic
Sets the metallic value of the graphic material.
graphic_material SetMetallic value
HyperView Tcl Modify
This command sets the metallic value of the graphic material (float 0.0 to 100.0).
To set the metallic value of a graphic material:
hwi OpenStack
session_handle GetClientManagerHandle post_manager_handle Animation
post_manager_handle GetGraphicMaterialHandle brass 3
brass SetMetallic 80.0
hwi CloseStack
None.
