poIImagePlane SetVidTrackingWindowSize
Sets the size of the window used for video tracking.
Imageplane_handle SetVidTrackingWindowSize size
HyperView Tcl Modify
This command sets the the size of the window that CalcVidTracking searches after each frame to find the tracking point.
size
An integer value between 5 and 50.
To set the size of the tracking window to 10:
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetImagePlaneCtrlHandle ipc_handle
ipc_handle GetImagePlaneHandle image_plane_handle 1
image_plane_handle SetVidTrackingWindowSize 10
hwi CloseStack
Returns HW_InvalidHandle if the image plane handle is invalid, or HW_Error if the size is not an integer or is not between 5 and 50.
