poIIsoValueCtrl SetLayer
Sets the current layer.
poIIsoValueCtrl_handle SetLayer layer
HyperView Tcl Modify
This command sets the current layer.
Note: The scalar storage within HyperView can accept a layer or a derived quantity of all layers (see below).
layer
The layer label or one of the following derived types:
max
Store the maximum value of all layers.
min
Store the minimum value of all layers.
extreme
Store the maximum absolute value of all layers.
sum
Stores the (scalar) sum of all values among the layers for each entity.
average
Stores the (scalar) average value among the layers which contain data for each entity.
range
Stores the difference between the maximum and minimum values among the layers for each entity.
maxlayer
Stores the layer number (instead of the actual value) which contributed to the maximum value for each entity.
minlayer
Stores the layer number (instead of the actual value) which contributed to the minimum value for each entity.
extremelayer
Stores the layer number (instead of the actual value) which contributed to the maximum values for each entity.
Note: Only in the case of results based at the elemental centroid, would one layer per element be displayed. For corner bound or nodal bound results (in the case of averaging), different layers may contribute to the max/min/extreme value at each corner/node of the same element.
Returns 0 if successful, otherwise an error code.
