poINote SetColorMode
Sets the color mode for the border of the note.
poINote_handle SetColorMode mode
HyperView Tcl Modify
This command sets the color mode for the border of the note.
mode
The color mode to be set. The following options are available:
"User"
Allows you to specify a user defined color using the poINote SetColor command.
"Component"
The color to which the entity is attached will be used (if available), otherwise the default color will be used.
"Contour"
The contour color of the entity to which the note is attached will be used. If no contour is available, gray will be used.
Returns 0 if successful, otherwise an error code.
