poIPart GetShadeMode
Gets the shading mode for a specific part and overrides the global setting that was set with poIRenderOptions GetShadeMode.
poIPart_handle GetShadeMode
HyperView Tcl Query
This command retrieves the shading mode for a specific part and overrides the global setting that was set with poIRenderOptions GetShadeMode.
Note: This command is used for the special shading mode that is applied to primitive geometric objects that occur in MBD models.
Error
Returns flat or smooth. Smooth is the default.
