poISystem GetType
Gets the coordinate system type.
poISystem_handle GetType
HyperView Tcl Query
This command returns the coordinate system type (rectangular, cylindrical, or spherical).
None.
Creates a coordinate system at the circle center defined by three nodes.
Gets the coordinate system color.
Gets the coordinate system's group ID.
Gets the coordinate system's ID.
Gets the coordinate system's ID visibility.
Gets the coordinate system move type.
Gets the orientation of the coordinate system.
Gets the origin of the coordinate system.
Gets the coordinate system's parent system ID.
Gets the coordinate system's visibility.
Sets the coordinate system color.
Sets the coordinate system's ID visibility.
Sets the orientation of the coordinate system.
Sets the orientation of the coordinate system using the coordinate values of three nodes.
Sets the orientation of the coordinate system using three nodes.
Sets the origin for the coordinate system.
Converts a system to a user-defined system.
Sets the coordinate system's visibility.
ON THIS PAGE
HyperView Tcl Query
None.
ON THIS PAGE
