Post Processing
Explore SnRD Post Processing User Interface.
- Launch HyperWorks and switch to the HyperView client.
From the menu bar, click File > Load > Preferences File.
The Preferences dialog opens.
Select Squeak & Rattle and click
Load.
The SnRD menu in the HyperView client is created.
Select SnRD > SnRD-Post.
The SnRD Post Processing tool is launched. You can use the SnRD Post Processing tool to do the following:
- Load files and Post Process results.
- Perform Sensitivity Analysis to understand and evaluate modal sensitivity.
- Study Squeak and Rattle effects under Combined Loadings.
- Setup Optimization solver decks after evaluating modal sensitivity and elimination methods.
- Study and analyze Stochastics and Design of Experiment runs.
