Technical Concepts
Technology and problem evaluation approaches used in SnRD.
Capturing Squeak and Rattle Issues
Squeak and Rattle issues are always caused by relative displacement between two components which are mounted with or without any gap, and might interact for a short duration of time. This means, if there is no relative displacement, then there are no squeak and rattle issues.
- Acoustics method: Issues are captured using acoustical methods, and these captured sound quality will define the squeak and rattle issues.
- Laser Scanning Vibrometer is an instrument for rapid non-contact measurement and imaging of vibration.
SnRD Methodology
The power of Virtual Simulation enables you to successfully design and engineer innovative products for today’s competitive environment. The ability to analyze the multifaceted physical performance characteristics of a design, before any prototype is made, can substantially increase productivity. Companies need robust simulation tools to efficiently overcome time, budget, and quality constraints.
The development of the Squeak and Rattle Director is based on the above principle. This tool will help CAE analysts in identifying the locations of squeak and rattle noises based on multiple risk analysis capabilities. Moreover, SnRD enables root cause analysis and diagnosis of the issues detected, enabling communication to other stakeholders, such as designers and manufacturing. This problem solving is the key in development cycles, therefore SnRD has been enhanced with Optimization setup to guide you in proposing efficient design changes.
