Root Cause Analysis
From risk detection to problem solving, the diagnosis and root cause identification is a necessary step. SnRD Post-Processing proposes two modules: Modal Contribution and Modal Sensitivity.
Modal Contribution
The E-Line method is a time domain analysis approach, using Modal Transient Analysis, also known as the Modal Superposition Method. This enables a transition to the frequency domain.
Where:
  • U(t) is the time domain displacement
  • N is the number of modes extracted
  • mi is the Modal displacement for a mode i
  • ѱi is the Participation factor for mode i
With all the above responses available in the standard outputs from OptiStruct Analysis, the Relative Modal Contribution [%] values can be calculated. These will describe the participation of a mode or modes on a peak of the time domain response.
Modal Sensitivity
Use modal sensitivity to live perform what-if studies by altering the time domain response of an E-Point or complete E-Line. This is achieved by decomposition of the Modal Superposition response, applying a factor (between 0 and 1) on selected modes, damping, and canceling or isolating them.
Figure 3.
