Squeak Evaluation
The squeak evaluation is based on the contact plane relative displacement. As per the
E-Line method definition, in X and Y local Direction. The Max
Relative Peak to Peak amplitudes, also called MAX Principal Peak to Peak (MAX
Principal P2P
), are compared to the inverse of Impulse
Rate
[mm] (IR-1) values from the specific pair of materials
along each E-Line.
