View new features for HyperWorks 2022.
Explore the GeoD user interface.
MotionView is a general pre-processor for Multi-body Dynamics.
MotionView has many pre-processing and post-processing capabilities with regards to flexible bodies, or flexbodies, for multi-body dynamics models.
From the Preferences dialog, you can access various MotionView options for your model.
The AutoBumpStop entity limits suspension travel in bump (also known as jounce). When the distance between two bodies becomes small, the AutoBumpStop applies a force to push the bodies apart.
The AutoReboundStop entity limits suspension travel in rebound (also known as droop). When the distance between two bodies becomes large, the AutoReboundStop applies a force to pull the bodies together.
The AutoRider models the mass and inertia of a human body and includes graphics for the human body.
The AutoDamper entity is a force-velocity model designed to easily simulate a shock absorber used in ground vehicles. The AutoDamper entity reads force-velocity data from a file written in the TeimOrbit format.
Reference material for the HyperWorks Desktop scripting interface which is a set of Tcl/Tk commands.
ON THIS PAGE
ON THIS PAGE
