Review Results
Once the solution is completed, the results can be visualized using Animate button in the Run panel. A HyperView (Animation client in Altair HyperWorks) window is added and result file is loaded.
From the Animation toolbar, click the Start/Pause Animation button
 to visualize the animation.
Results can also be plotted using the Plot button in the MotionView Run panel. HyperGraph (Plot client in Altair HyperWorks) window gets added with the plot file (.abf) corresponding to the run is loaded.
Figure 1. HyperView and HyperGraph 2D
