HyperWorks
HyperWorks
2022
  1. Home
  2. Plot Data
  3. 3D Chart
  4. Define
    Edit existing curves or add new curves to the current plot.
  5. Copy and Paste Data Point Values
  • What's New
  • Get Started
  • Video Tutorials
  • Manage Files and Data
  • Sessions and Report Templates
  • Sketching
  • Geometry
  • FE Geometry
  • Meshing
  • Elements
  • Model Build and Assembly
  • Composites
  • Connectors
  • Morph
  • Skeleton Modeling
  • Design Space
  • Design Explorer
  • Validate
  • Crash and Safety
  • Airbag Solutions
  • Aerospace
  • Aeroelasticity
  • Certification
  • Marine
  • Squeak and Rattle Director
  • Geomechanics Director
  • Panels
  • Results Data
  • Plot Data
  • Multibody Modeling
  • Media Files
  • Tabulate Results
  • Text Files
  • Publishing and Reporting
Index
HyperWorks
2022
HyperWorks
  • What's New
    View new features for HyperWorks 2022.
  • Get Started
  • Video Tutorials
  • Sketching
  • Geometry
  • FE Geometry
  • Meshing
  • Elements
  • Composites
  • Connectors
  • Morph
  • Skeleton Modeling
  • Design Space
  • Design Explorer
  • Validate
  • Crash and Safety
  • Airbag Solutions
  • Aerospace
  • Aeroelasticity
  • Certification
  • Marine
    Explore the GeoD user interface.
  • Panels
  • Results Data
  • Plot Data
    • Working with Plots
      Learn how to manipulate plot data using the Plot Browser and other user interface tools and options.
    • Line Chart
    • Bar Chart
    • Complex Chart
    • Polar Chart
    • Vector Chart
    • Radar Chart
    • 3D Chart
      • Create Curves by File
        Loads Flux motor efficiency files in text format.
      • Define
        • Add a Curve
        • Copy and Paste Data Point Values
        • Cut Data Point Values
        • Cut, Copy, and Paste Curves
        • Display the Curves Dialog
        • Edit a Curve with File as a Data Source
        • Insert Data Point Values
        • Rename a Curve
        • Turn a Curve On or Off
        • Use File as a Data Source
        • Use Math as a Data Source
        • Use Values as a Data Source
      • Waterfall
        Create waterfall plots from XY force response data and input pulses.
      • Curve Style
        Define curve attributes.
      • Axes
        Axes can be added to plots using the Axes panel.
      • Values
        Retrieve individual point data on any curve in the active window.
      • Data Query
        The Data Query panel uses vertical cutting surfaces for viewing and plotting non-planer cross sections.
      • Annotate
        Provides quick access to the Datums and Notes tools.
      • 3D Chart Context Sensitive Menu
        From the HyperGraph 3D3D Chart modeling window, right-click to display the context menu.
  • Media Files
  • Tabulate Results
  • Text Files
View All Altair Simulation Help
HyperWorks
HyperWorks
2022
  1. Home
  2. Plot Data
  3. 3D Chart
  4. Define
  • What's New
  • Get Started
  • Video Tutorials
  • Sketching
  • Geometry
  • FE Geometry
  • Meshing
  • Elements
  • Composites
  • Connectors
  • Morph
  • Skeleton Modeling
  • Design Space
  • Design Explorer
  • Validate
  • Crash and Safety
  • Airbag Solutions
  • Aerospace
  • Aeroelasticity
  • Certification
  • Marine
  • Panels
  • Results Data
  • Plot Data
  • Media Files
  • Tabulate Results
  • Text Files
Index
  1. From the Define panel, select Values.
  2. Select a point from the table.
  3. Click Copy.
  4. Click Paste.
    The data points are added to the next row in the table.
