Generate H3D from EDEM Results
This tool helps to convert EDEM particle simulation results to animation H3D that can be visualized in HyperView.
From the Analyze ribbon, Tools tool set, select H3D from EDEM from the Tools drop-down menu to access the dialog.
The inputs required are as follows:
| EDEM input deck | EDEM file (*.dem) that contains simulation results. |
| H3D units | Length units needed in H3D. |
See Also
