Import Models
Import a model using Model Verification.
                In the Comparison/Verification Browser, right-click and
                    select Import from the context menu.
                The Import - Model Verification dialog opens.
                Select Import Type for Base Model.
- XML (PLMXML or UDMXML)
 - Assembly (CAD assembly files: UG Assembly, CATProduct, JT Assembly…)
 - CAD (Refer Config / CAD section)
 - FE (Refer Config / FE section)
 - Multiple Assembly (Multiple CAD assembly files)
 - Spot Files (Refer Config / FE / Connector section)
 - FE File (direct file selection)
 - Mixed Import (folder contains CAD and FE files)
                Select a datatype.
                Respective data types will be listed.
                Click the folder icon and navigate to the model to import (Folder/File
                    selections).
Figure 1. -
                Choose a method for running the model.
- Choose Interactive to run the model in the same HyperWorks session.
 - Choose Background to launch a new HyperWorks session in batch mode.
                The Processes drop-down list becomes active when you select
                        Background, and it also depends on the processor. The
                    Model Verification tool launches as many hmbatch processes selected.
- Choose Check to execute only the comparison without the report generation.
 - Choose Report to generate only the Reports (Check executed previously).
 - Choose Both to perform the comparison report generation sequentially.
 - Click Run to execute the function.
                Click Stop to stop the operation.
                This closes front and background HyperWorks sessions. The Comparison/Intersection Browser is populated with the parts structure.Note: This function can be used to create XML or to review the model. This function is included in all Verification and Comparison functions.
