Open the Verification Browser
Use the Verification Browser to inspect CAD data supplied from your design or CAD team.
The Verification Browser supports Offset, Intersection, Spot Weld, Connection, Spot Comparison, and Free Part checks. After performing the verification, results are exported to reports.
Browser User Interface
Overview of the Verification and Comparison Browser user interfaces.
The Verification and Comparison Browsers consists of a search, filter, column data and Entity Editor.
You can switch to the Part Browser any time to perform detailed operations on a part.
Column Details
- Name
 - Description
 - ID
 - Part assembly and model IDs.
 - Color
 - Part entity colors.
 - MVD Part Name
 - Part entity name.
 - MVD PID
 - Entity specific property ID’s. At the part level, the IDs for referenced properties are displayed. At Component level, IDs of the referenced properties are displayed.
 - UID
 - Part assembly and part Unique IDs.
 - MVD Revision
 - Major revision, Study revision, and Library Part revision.
 - MVD Material
 - Material name of the part.
 - MVD Design Material
 - Design material from CAD metadata.
 - MVD Thickness
 - Entity specific thickness. At the part level, it displays the thicknesses of the referenced properties. At component level, it shows the thickness of the referenced property.
 - MVD Design Thickness
 - Design thickness from CAD metadata.
 - MVD Contact Thickness
 - Contact thickness from CAD metadata.
 - MVD Material Query
 - 0 or 1.
 - MVD Vendor
 - String of vendor names – you must write some text for reference.
 - MVD Action
 - Type of operation for the part entity.
 - MVD Modeling Type
 - Type of modeling – either mid-plan or skin mesh for the part entity.
 - MVD Status
 - String of text – you must write some text for reference
 - MVD Mesh Size
 - Mesh size for the part entity.
 - MVD Solver
 - Solver name string – you must write the value.
 - MVD PID Rule
 - Keep existing or incoming IDs.
 - MVD Match %
 - Similarity value of both parts. For detailed calculation, see Generate Comparison Results.
 - MVD Base PID
 - Part ID of the CAD/FE part that is topologically matching.
 - MVD Base Material
 - Material name of the CAD/FE part that is topologically matching.
 - MVD Base Thk
 - Thickness value of the CAD/FE part that is topologically matching.
 - MVD Error
 - Errors accrued in respective operation on the part.
 - MVD Function Name
 - Sub assembly name of the part.
 - MVD Assembly Name
 - Assembly name of the part.
 - MVD Counter Parts
 - Matching or intersecting part’s UDMID.
 - MVD Bounding Box
 - Bounding box of the part.
 - MVD Oriented Bounding Box
 - Oriented bounding box of the part.
 - MVD Weight
 - Weight of the part.
 - MVD Delta Weight
 - Weight difference between part and counter part.
 - MVD Load Collectors
 - Load collector card name of the part.
 - MVD Contacts
 - Contact card names of the part.
 - MVD Boundary Conditions
 - BCs card names of the part.
 - MVD Representation File
 - Default representation file path of the part.
Context Menu
Overview of the Verification and Comparison Browser context menus.
