FE geometry is topology on top of mesh, meaning CAD and mesh exist as a single entity. The purpose of FE geometry
is to add vertices, edges, surfaces, and solids on FE models which have no CAD geometry.
Right-click at the Report or Chapter level and select Add > Items > Table.
Or
From the Report Ribbon, Add Item tool group, click
Table.Figure 1.
Below are the properties associated with the Table entity. Figure 2.
Name
You change the name property of the table item.
Caption
Provide a caption for the table entity. This caption is visible in
the exported Document report.
Source
Select the data input type for the table entity. Available options
are:Figure 3.
Data
Edit data to the table entity. Data entry to the table
can be done through two methods. Figure 4.
Manual: Enter the required number of rows and
columns and click Update.
This adds the number of rows and columns where you
can enter the data manually. Figure 5.
Import: You can also import table data from a
CSV or XLSX file.
Click Import. A file
browser option is displayed.
Select a file and click OK. This imports the
data from the file and populates it in the table
entity.
External CSV/XLSX
Import data from a CSV or an XLSX file. Select the
required file and define the cell range to be imported
to the table entity.Figure 6.
TableView Window
Import data to the table entity from the TableView
window in the session. Select the TableView page/window
for Location, define the cell
range and other advanced options.Figure 7.
HyperMesh Table
Import data to the table entity from an existing
HyperMesh Table collector in the session. Select the
HyperMesh page/window for
Location and select the
required table from the Table
list.Figure 8.
Matrix Browser Table
Use Matrix Browser table and Matrix Browser Macro script
to generate data for the table entity.Figure 9.
Advanced
Location of Caption
Select the caption location from the list. These are
standard locations as present in Microsoft Word. Table
caption locations can be: Figure 10.
Auto Split Table
Provides the function to split up tables automatically
based on the space available in the slide or page.
If Auto Split Table is disabled, Report allows you to
split the table based on your requirement. Figure 11.
By
Select if you want to split the table along the columns
or rows.
Maximum Rows
Enter the value for the maximum number of rows for the
table.
Maximum Columns
Enter the value for the maximum number of columns for
the table.
