Ale Fsi Projection entities provide a coupling method for simulating the interaction between a Lagrangian material
set (structure) and ALE material set (fluid).
Ale Reference System Curve entities defines a motion and/or a deformation prescribed for a geometric entity, where
a geometric entity may be any part, part set, node set, or segment set.
Ale Reference System Switch entities allows for the time-dependent switches between different types of reference systems,
that is, switching to multiple PRTYPEs at different times during the simulation.
Ale Tank Test keyword provides curve through an engineering approximation when control volume airbags only require
two engineering curves to define gas inflator and those two curves can be experimentally measured but the ALE inflator
needs one additional state variable - the inlet gas velocity which is impractical to obtain.
In LS-DYNA, damping entities define damping applied on the parts and nodes in case of *DAMPING_GLOBAL. In Radioss, damping entities used to set Rayleigh mass and stiffness damping coefficients are applied to a set of nodes
used to stabilize the results.
When source data is not in the correct location and overlaps with the target model, the tools provided in the Field Realization dialog can be used to transform the source model to the target model's location with linear transformation,
rotation, or scale methods.
Joint entities define the kinematic relationship between two bodies (for Ball, Cylinder, Revolute, Slider joints) or three
bodies (for DoubleSlider joints).
Perturbation entities provide a means of defining deviations from the designed structure, such as buckling imperfections.
Define the stochastic variation in the material models with the STOCHASTIC keyword option.
Region entities store information used to facilitate and automate modeling practices and processes. It enables a selection
which can be common across design changes or other models, provided region data is the same.
State Equations are used to describe the thermodynamic equation relating material state variables under a given set
of physical conditions, such as pressure, volume, temperature, or internal energy. State Equations are useful in describing
the properties of fluids, mixtures of fluids, and so on.
Transformation entities define solver transformations, and are used to define a transformation sequence in a Position
entity, to be applied on a set of nodes or on a SolverSubmodel.
The transformed source model will be stored with the field entity and will remain
in the database for future reviews.
Open or import the target model.
Create and define a field entity:
In the Modelブラウザ, right-click and select Create > Field from the menu.
In the エンティティエディター, define the source model
data (results, csv, and current model).
Realize the field:
Realize from the menu.
In the Field Realization dialog, define the
realization settings.
Click 適用(Apply).
In the Field Realization dialog, click
Review to display the target model (green) and the
source model (pink).
Transform the source data:
In the Field Realization dialog, click the
Transform button.
In the Field Transformation dialog, define
settings in the Type field to perform either a Translation, Rotation, or
Scale transformation of the source node.
Click the Close button to perform the
transformation operation.
Click Reset Review to display the updated
location of the new source model.
Repeat this operation until the source model and the target model are
in the same location.
注: Manually define the vector direction by entering the Source node x,y,z
location, Target node x,y,z location, and Magnitude of the vector.
