Define the Property File
Click the Property file folder icon, and locate a
.gbs file to define the force characteristics of your
bushing. The .gbs file includes information such as
deflection, velocity, force, and torque.
注: For a paired bushing, the follower side of the bushing is grayed out.
- Check the Output check box to direct the solver to output the bushing force, deflection, and velocity. Deselect the box to disable the output and reduce the size of output files.
Click View File to load the property file in a text
window.
The file loads in a text editor if you registered a text editor as a HyperWorks Preference.
