MODCHG
Subcase Information Entry The MODCHG command can be used to remove and/or reactivate contact interfaces and/or elements for this subcase. It is used only for nonlinear analysis.
Contact activation or deactivation via TYPE=CONTACT on the MODCHG Bulk Data Entry is additionally supported for optimization runs.
Note: TYPE=ELMSET is not supported for optimization.
MODCHG = option
Argument Options Description
option <SID>
No default
SID
Set identification of a MODCHG Bulk Data Entry.
  1. MODCHG Bulk Data Entries will not be used unless selected in the Subcase Information section.
  2. For a fresh nonlinear analysis subcase (without any CNTNLSUB or with CNTNLSUB prescribed to be NO), a contact interface and a set of elements can be active or inactive depending on whether and how they are referenced by MODCHG.
    Contact and/or Elements
    Active/Inactive
    Removed with MODCHG
    Inactive
    Added with MODCHG
    Active
    Others
    Active
  3. For a subsequent nonlinear analysis subcase (with CNTNLSUB prescribed to be YES or a subcase ID), a contact interface and a set of elements can be active or inactive depending on whether and how they are referenced by MODCHG and whether they are active or not in the preceding subcase.
    Active/Inactive
    Removed with MODCHG
    Inactive
    Added with MODCHG
    Active
    Others
    Active, if active in the preceding subcase
    Inactive, if inactive in the preceding subcase.
