SEDR
Subcase Information Entry Defines the Superelement Identification Numbers for which Data Recovery is performed for One-Step Superelement Analysis.
SEDR = option
Argument Options Description
option <ALL, SID, or SEID>
ALL (Default)
Data Recovery is conducted for all superelements.
SID
SET entry identification number, which lists the superelements for data recovery.
SEID
Superelement for data recovery identification number.
  1. The SEDR entry should be specified above the first subcase.
  2. Data recovery is conducted for all superelements if the SEDR entry is not present.
