SUPER
Subcase Information Entry The SUPER command can be used in the Subcase Information section to assign a subcase to a superelement or a set of superelements.
SUPER = option
Argument Options Description
option <0, ALL, ID>
No default
0, ALL
Selects all the active superelements already generated before the current SUBCASE.
ID
Selects the superelement with the corresponding identification number.
  1. Only one SUPER entry can be present in each subcase.
  2. SUPER refers to the SESET Bulk Data Entry which defines the interior points of a given superelement.
  3. All the elements attached to the GRIDs in SESET would be included during the generation of the corresponding superelement.
