SESET
Bulk Data Entry Defines the interior grid points for One-Step Superelement Analysis.
SESET SEID G1 G2 G3 G4 G5 G6 G7
Alternate Format
SESET SEID G1 THRU G2
SESET 4 333 12 556 99 5
SEID Superelement identification number.
No default (Integer ≥ 0)
Gi Grid or Scalar Point identification numbers.
Default = Blank (Integer > 0, or THRU)
  1. Grid point entries via Gi should not be repeated on the SESET entry.
  2. If the THRU option is used, then G1 should always be less than G2.
